dragoneggs
- Mark
- Dec 14, 2021
- Seabeck, WA
- '22 Snazzberry Pearl JLR
- Build Thread
- Link
Here is my RockHard Aluminum Mid width front bumper with recessed winch along with some Baja LP4s. This is a toad behind my RV so I am trying to keep its weight down.
The OEM LED fogs plug in perfectly. I did the install myself. Yeah the Warn winch is a super tight fit. That is once you do a little grinding on the frame end flanges. If you have some DIY skills, dive in. I would be happy to advise.
I love the low profile and not restricting the airflow. Note also I had them 'delete' the bull bar. I didn't want it interfering with the front cam for crawling.
Note the clevis fittings specifically designed for towing. They tie directly into the frame ends.
