Rangemaster
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
How does the EVO enforcer lift ride/handle on/off road?
I have not taken it offroad yet, been too busy and only drove it maybe 30 miles. With those shocks and tires it still feels stock behind the wheel. The speed bumps in parking lots are no issue with the shocks, you almost dont have to slow down for them.
Rangemaster
Rangemaster
Nevada
Business Owner
Here is m.o.r.e. Fire extinguisher mount.
Jeep Wrangler JL Rangemasters JL Diesel Build 28383F08-4BAB-4E1B-8734-D00CCCB51AF5
Rangemaster
Rangemaster
Nevada
Business Owner
Well today I installed the ARB twin compressor with the more mount and wiring harness from:
https://expeditionessentials.com/co...ts/bedside-compressor-mount-extension-harness
I routed the wiring harness under the drivers side door trim. Be careful removing the trim when its cold. I broke a few plastic clips when removing the trim. I had to remove the clip from the wiring harness to work the harness through the plastic plug in the firewall. Has you can see everything turned out great. I can control the compressor from aux switch on my dash. Main power is routed through the relay for the winch so the compressor has no power going to it unless you hit the aux switch to turn on the relay.
Jeep Wrangler JL Rangemasters JL Diesel Build 674B553D-57EC-4324-A349-53F1C67B2552
Jeep Wrangler JL Rangemasters JL Diesel Build 24F289B6-99F8-4C17-9C37-C38931309B2E
Jeep Wrangler JL Rangemasters JL Diesel Build DA1190A4-E11D-44E6-B832-4EE5F3572FFF
Jeep Wrangler JL Rangemasters JL Diesel Build 0B448C4E-088F-4B75-B0D2-5EADB371FA0B
Jeep Wrangler JL Rangemasters JL Diesel Build 2E4DA289-C5CF-42AD-82B2-997C6B65CEC8
Jeep Wrangler JL Rangemasters JL Diesel Build F131449B-D1CD-48F5-8499-D330668286BE
Jeep Wrangler JL Rangemasters JL Diesel Build A2C40D94-9874-4265-B1CC-B93C0EF82CED
Jeep Wrangler JL Rangemasters JL Diesel Build F86E75CC-1714-4CF6-BE1C-846C66892273
Roky
Roky
Nice work! Do you have the same aux switch turning on power to winch and compressor?
Rangemaster
Rangemaster
Nevada
Business Owner
yes, you can only use one at a time.
Rangemaster
Rangemaster
Nevada
Business Owner
aham23
A
Arizona
2021 JLU Rubicon
When you say clip do you mean the connector of the harness that plugs into the compressor? I need to remove that to run my wire but not seeing how to disconnect the 4 wires into it.
Rangemaster
Rangemaster
Nevada
Business Owner
You will need a little tiny screwdriver and you slide it in the connector by each wire and it will release the wire from the connector. Make sure you take a picture of the connector and wires so you get them back at the same place.
Rangemaster
Rangemaster
Nevada
Business Owner
Got the rear hi-lift jack installed in the rear of the jeep. I found if you use a wood shim and wedge it down in the jack it will stop the rattle.
Jeep Wrangler JL Rangemasters JL Diesel Build 59E907A2-C4F5-428D-98CF-D39CE4CF5425
Jeep Wrangler JL Rangemasters JL Diesel Build 7A8042F6-76C5-4A29-8C92-B135FD2A6F7A
Rangemaster
Rangemaster
Nevada
Business Owner
Rangemaster
Rangemaster
Nevada
Business Owner
Here is pics of the KC Hi Lights, I got in a few weeks ago. Took almost 3 months to get, installation was easy was done in a hour or so. Don’t care for the yellow lettering, ordered new white stickers to cover this up.
Jeep Wrangler JL Rangemasters JL Diesel Build 8F05E2ED-9DB4-4775-9A3A-3F1B056E4633
Jeep Wrangler JL Rangemasters JL Diesel Build B267E6A6-6BE1-47DC-A259-580205560867
Jeep Wrangler JL Rangemasters JL Diesel Build 0E3744DA-CEBA-4774-A71F-DF35FA2A75B3
Rangemaster
Rangemaster
Nevada
Business Owner
Here is pics of the KC lights with the new stickers.
Jeep Wrangler JL Rangemasters JL Diesel Build FD51890B-3044-4F7C-8382-508627793EE1
Jeep Wrangler JL Rangemasters JL Diesel Build BD990E8C-F609-43A8-8215-69343ED35336
