Perfect! That’s what they should look like!35x12.50x17 Nitto Ridge Grapples on stock Rubicon wheels no lift no spacers.
Do you have to reinforce and hardware on your wrangler when you go with 37’s?Laid the stock 33’s up against the 37’s.. interesting perspective
General consensus is yes. It’s iffy on 35s. I would not risk it with 37s.Do you have to reinforce and hardware on your wrangler when you go with 37’s?
I’d love to know how it rides too. Also what tires are those. Very nice looking wheel & tire combo.How is the ride did you loose power from. Stock did you get a hybrid . How does. Ride compare to 33 what difference do you not rice I am using it as my daily driver what are your thoughts
WOW What a difference. I have the 2in lift and 35's and its a BIG step up to get into the Jeep. Looks awesome !My 37's went on today. Wow what a difference. I've read from so many here that the 37's don't really impact driving and it seems like everyone is correct. I could tell that there was bigger tires but it really didn't slow the Jeep down. Acceleration and stopping was nearly unchanged. I used the RC spare tire bracket but I have a Mopar reinforcement and relocation bracket coming. This tire would not have fit without some sort of bracket. I raised the 3rd brake light and it fits fine. Love the look.
What’s all involved to reinforce suspension? What is the price to reinforce it? Forgive me I’m a newbie. ThanksGeneral consensus is yes. It’s iffy on 35s. I would not risk it with 37s.
It’s a good step. Only slightly more then on my JK with 35’s.WOW What a difference. I have the 2in lift and 35's and its a BIG step up to get into the Jeep. Looks awesome !
I will stick with the 35’s and go with a spacer lift. I won’t be doing any extreme off-road rock climbing just running through some trails and semi deep muddy streams etc. Will a spacer lift do for what I have in mind?@Kata, I think AUG thought you were referring to tailgate reinforcements when storing the tire on the rear tire carrier. It's "iffy" if you want to try to store a 35 (depending on combined weight) and mandatory to reinforce your tailgate with a 37 inch wheel/tire.
If you were referring to suspension, unless you have a Rubicon, you would need to have a lift installed to fit/run 37 inch tires. Rubicon models are already somewhat lifted, and only need 2+ inches of lift to properly support a 37 properly. All other models pretty much require a larger lift, which your local shop would be better positioned to recommend. Hope that helps!
@Sting_NC_USA was correct - sorry, I thought you were talking about the tire carrier.I will stick with the 35’s and go with a spacer lift. I won’t be doing any extreme off-road rock climbing just running through some trails and semi deep muddy streams etc. Will a spacer lift do for what I have in mind?
Are you able to use the Mopar tailgate reinforcement without the oversized tire carrier? I was hoping to just buy the reinforcement for the tailgate for peace of mind with 35's but on the mopar catalog it says it "requires the oversized carrier." Any info is greatly appreciated!It was a 1 1/2 spacer, Its just temporary till mopar comes out with 2nd part of oversized tire carrier, I have the heavy duty hinges on now hopefully will hold up its kind of resting on edge of bumper now
What dealer did you go to? I'm in the Dallas area as wellMy dealer in Dallas, has flashed 4 so far, they said they have to get an individual Jeep specific code for each Jeep, and it allows them to calibrate the speedometer, tire size (31-44”), gear ratio 3.21 to 5.13, transmission shift points, and I forgot to ask them about TPMS. $150 each flash or visit. So yes, the dealers that know how can flash the JL’s computers and do the same thing the programmers did in the JK.
Yours is my favorite!Pro Comp 5044-7973 Syndrome Series 44 (17x9)
BFGoodrich All-Terrain T/A KO2 Tire (35x12.5x17)
Stock suspension. Stock carrier.
Oooooooo! Yours is my favorite too!Installed Mopar lift last Saturday and got 37’s Monday.
here is mine.
2" mopar Lift
17" ICON Alloy Alphas
37x12.50x17 Nitto Ridge Grapplers
Mopar Performance Rock Rails
Mopar Tailgate Kit & Taillight Relocation Kit
Oh and how can this beauty not be my favorite too! LOLHappy to contribute:
Evo 2.5 Boost, shock extensions and drop brackets.
Battle Born Bootlegger Beadlocks 17x9, 3.5" backspacing
Cooper STT Pro 37x13.5
I'm in love with this Jeep.
AustinE, post: 127442, member: 14048"]here is mine.PM sent so we remember to touch base when we both make decisions!
Good year MTRs make a C in a 35 12.5 17 I have it now. Good tire a little noise on the road but a good tire.I am happy with them. I couldn't pass the deal i got on them. A friend that is a manager at discount tire took them back with 400 miles from a customer who never had MTs before. He thought they were to loud.so i got all 5 for 1100 and the traded my 285s i had bought a year ago at the time and got 300 for them. So 800 for 5 MTRs with 400 miles i said put them on. Sometimes you can find deals like that because discount tire will let you take you tires back and trade them in if you are not happy if they still have very low miles. So if you want a C in 35 mud tire check them outSo I don’t want to poke the bear I have been leaning toward Nitto RGs... but the STT Pros have caught my eye lately.
I’m on road 99%, highway miles. Are the STT Pros workable when it comes to road noise and comfort?
Comparing 35s... I’d love an aggressive 35 in load C for comfort, but can’t find one.
