RonAZ
- Ron
- Mar 7, 2018
- Scottsdale, Arizona
- 2018 JLUR
Looking forward to checking it out at Moab.
Can you elaborate on the "tight fit"? Is that between the frame rails, front to back, etc.? Also, did you have to modify ANYTHING to make that combo work? I've got the JCR Plate coming on Monday and have the Warn 10s as well. Thanks in advance.We finished off the install with a bright red Maximus fairlead and a Factor55 Flatlink hook.
The WARN Zeon 10-S is a tight fit, but gotta say that WARN did a great job with the JL Rubicon winch plate, everything went together smoothly.
Here is a quick AFTER shot:
I would guess the why is Stated on the insert. My guess is that the mounting brackets were for a JK and maybe you need different ones for the JL. I would be curious if they charge you for these extra parts or they ship them to you free.There there is an insert inside the warm 10S box advising to call warn before install on JLs. Any idea why?
We received more info from WARN and it is addressed in this thread: WARN ZEON Winch NoticeThere there is an insert inside the warm 10S box advising to call warn before install on JLs. Any idea why?
I was going to ask a something similar - what are the specs on those wheels, and what is your new overall width and height? Thanks!Thinking of getting the same rims. Can we get a picture from the front of the JL to see the 0 offset, and how much they stickout? Do they not come with centercaps?
The wheels are KMC XD231 beadlock wheels: 17"x8.5" with a 4-3/4" backspace.Love this build!
I have the same JLUR (Firecracker Red matching top and fenders) on order and am looking at the EVO 2.5” Stage 2 boost for my lift.
May I ask- what size wheels and offset are you running?
I plan to run 37” Nitto Ridge Grapplers on 17” wheels, want to make sure they will fit and look right. Looks like your setup has just the right combo!
Thanks
