thescreenking
- Chris
- May 27, 2020
- port charlotte, fl
- 2020 TJU
I am completely redoing the Jeep sound and head unit/infotainment center with Stinger Height10 and full factory PAC integration (still in Beta). These systems should be shipping around the end of summer sometime.
The Height10 PAC integration Install is fairly straight forward if you follow the instructions that the team at Stinger/PAC have laid out. It is very tight in the JLU dash so the wiring and module placement has to be a certian way.
The install took about two hours. Tha time can be cut down after a couple of installs.
All and all the system is fairly bug free and maintains the factory HD camera. Something no one else is doing right now. The other manufacturers that are creating solutions for the JLU can keep the camera but are dumbing it down and not maintaining the HD quality that the Stinger unit is doing.
As you can see this unit gives the operator to utilize all of the factory computer goodies. It also utilizes the factory data points in the Jeep, something no one else is doing either, to keep it clean and factory.
This unit is hands down and amazing solution for jeep owners who want tha most out of their Jeep, sound and otherwise.
The Height10 has an onboarding microphone which sounds better than any remote mic I have ever seen.
It accomplishes sound quality with an inboard crossover and equalizer that rivals stand alone as and crossovers. It gives the operator great ability to control their music. All with a 10" screen and factory quality fit and finish all in one kit.
I will be continuing this thread with more pictures as I move through the build.
To come... Arc Audio. Full System
