tonygiotta
- Tony
- Aug 21, 2018
- Turlock, CA
- '18 Firecracker Red JLUR
- Build Thread
- Link
- Occupation
- Fire Captain
Ok, update time. So for the first bit of modern day technology that complicates things, we're going to talk about LEDs. Yes, LEDs are not always your friend. LED's are great for the most part, and are pretty much replacing incandescent bulbs for most all automotive applications. LED is short for Light Emitting Diode. While it's not important that you know how exactly a diode works, it is important that you know that diodes (typically the non light emitting varieties) are used as one-way check valves in electrical circuits. Jeepers often use them when tapping into their factory wiring in order to prevent back-feeding the system and throwing a CEL. On a wiring diagram, their symbol is an arrow pointing to a line. Diodes only allow current to flow the direction the arrow is pointing.
One of the places LEDs often turn up is in backlighting and/or indicator lighting for switches. Carling V-series switches have an upper light and a lower light, and Carling still sells them in both LED and incandescent versions. Options for their switch bodies include lights that are independently wired, lights that turn on with switch activation, or a combination of the two.
So how does this affect our installation? Well, if you're using a lighted switch, there are a wide variety of pinouts that you may encounter. If you buy a switch that is prewired so that the indicator light turns on when the switch is activated, it simplifies the wiring as the light shares a pin with the input. Let's say for example that you are using a basic ON/OFF switch for your Winch Power switch. It has a single indicator light that turns on when the switch is activated. You simply attach your 12V+ wire to the input, connect your IN/OUT Switch to the output, and then attach a ground to the third pin on the back of your switch so that the light circuit can be completed. When you turn on the switch, power flows from the input to the IN/OUT Switch and through the LED light. Easy peasy, for the 3-pin folks out there.
But what about 5-pin? Remember on a 5-pin control, we're using the Winch Power switch to supply ground (12V-) directly to the winch's control pack. If we hook up a 12V- to our input, the light is not going to receive any power, so the indicator will not work. With an incandescent lit switch, we can fool the indicator light into turning on by connecting 12V+ to the third (ground) pin, as incandescent lights don't care which way the current is flowing. An LED lit switch however will not allow the current to flow backwards, so the indicator light will still not work.
So, did you just figure out why that damn LED indicator light on your fancy new switch isn't working?...
