Ideal offset/backspacing JL
Fire Burns
Fire
CA
You must be confused...a 9" wide wheel with 0 offset has 5" of backspacing....not 4.5 as you wrote.
Sorry Bro. Yep, I was confused for a minute there.
captnjbk
BK
Padre Island
2019 Sting Gray Rubicon. 2017 Moto Guzzi V7.
After reading this entire thread like 3 times I think I know the answer but wanted to check to see if anyone is running a similar setup and what they thought, pics, etc.........
I want to put KO2s 315/70x17 on 8.5" rims that have -6 offset and 4.5 back spacing. JL Rubicon with 2.5" mopar lift.
By my calculations I will be 2.6" farther out than the stock 33s that are on there now.
Is that sticking out too far? What effect will it have? Concerns?
Thanks for any feedback.
twisty
bob
Fountain Hills, Arizona
2018 JL Rubicon White
That sounds about right. I'm on stock rims with the same tire and it sits to far in, Going to 38's and likely going the same size rim you are. Remember the outer bulge is not the tread. I just did a quick look and from tread to bulge is about 3/4 inch so I'm subtracting that from the 2.5 and getting 1 3/4 inches past the flares.
How far you want the tread sticking out is both a person and a legal issue. I want it just out a bit and for ME the 1 3/4 is acceptable. However mud flinging will be more of a problem for sure and you need to check your laws about going over.
Diego_JL20
Diego
Toronto
Wrangler Rubicon 2020
Clear fine now that I have the lift on
Nice wheels I'm looking for -44 offset for my Wrangler but are concerned about sticking out too much, what's the offset on yours, -18 or -44?
psdtime
Tom
2005 LJ Rubicon, 2016 Ram 2500 CTD, 2020 JLRU
I have -6 offset on 9" rims with 35/12.50s and although I like the look of my rims, I really don't like how the tires stick out. Also, I went through a little mud puddle the other day (not fast) and the whole side of the Jeep was sprayed. I couldn't take it anymore so last night I ordered some AEV +25 offset wheels. I don't love the way they look, but from the pictures I have seen on this forum, they seem to do a good job of bringing the tires back in. From the calculator that I found online (https://tiresize.com/wheel-offset-calculator/), it seems like they will bring the inner wall of the tire to almost exactly where the stock tire would be. Also, they use the stock lug nuts and were designed with our back-up camera in mind. My current wheels get in the way of the camera a bit, not too bad though. AEV is having a sale, buy 4 get one free, I think it is only good until the 9th. Northridge Offroad is where I ordered them from. Good Luck
jchie21
Reno, NV
2018 Jeep Wrangler JL Sport S 2D
Been looking at all the posts for best offset, I eventually went with -12offset. Got them from tire rack KMC KM544 Mesa 17x9 -12mm offset. All stock no lift (yet). But some major rubbing on the rear when you flex it out, but it's all clear in the front lock to lock; but forgot to check when it's full flexed.
Jeep Wrangler JL Ideal offset/backspacing JL IMG_8694 2
Jeep Wrangler JL Ideal offset/backspacing JL IMG_8695 2
Jeep Wrangler JL Ideal offset/backspacing JL IMG_8705.JPG
Jeep Wrangler JL Ideal offset/backspacing JL IMG_8706.JPG
Yovwmon
Adam
OH
Wrangler JL Altitude
Let’s see pics of 9” wide wheel, -12 offset and 4.5 backspacing with a 12.5 35” tire.
Pdiehm
Paul
Newark, DE
AML Investigator
so i am looking at the Ultra Hunter +10 offset (17x9) paired with 285/70R17 Toyo OC AT3. I run the Sahara, so the axle is slightly shorter than the Rubicon axle.
If I am understanding correctly, the wheel itself will be 1.33" further out than the +44.25mm stock tire + the tire sidewall bulge, so we're looking at about 1.5-2" outside the fender?
Does that math seem right? are we closer to 2" than 1.5"?
blnewt
New Mexico
Just ask @cosine he knows!
I'm running 8.5 +10 on 295/70s so your setup would be about 1/4" in from mine at the fenders
Jeep Wrangler JL Ideal offset/backspacing JL 100_4025.JPG
Jeep Wrangler JL Ideal offset/backspacing JL 100_4026.JPG
Jeep Wrangler JL Ideal offset/backspacing JL 100_4024.JPG
Pdiehm
Paul
Newark, DE
AML Investigator
Jeep Wrangler JL Ideal offset/backspacing JL 93A64F84-FE75-4523-935B-A44FFAF6FC25
17x9 -6 offset
Rubicon doesn’t help me that much since my axles aren’t as wide. I think I am in the 0 to +10 range. Seems to put me about 1.5-2” outside stock. Front tires have about 3/4 inside fender now, so may be about what I need to stay legal here
