Changing out the grill inserts and fog light bezels
Woodynj
Justin
NJ
2018 JL Sahara
Quick post on my experience changing out the silver trim on the Sahara grill and fog light bezels.
Total tome was about 1 hour 15 min.
Fog Light Bezels:
I was able to replace by taking out 3 clips in the back. Made it very simple.
Then use a 7MM socket to loosen the screw holding on the outside corner of the bezel.
Then I used panel pry tools to pull out the bezel. Once you pull out the bezel you need to remove the nut insert and put on the new bezel. Here is where it is located. Forgot to grad a pic while it was still there. Just use needle nose pliers to squeeze the end and it comes right out.
Installing the Grill Inserts:
I did not grab many pictures but just take it slow and be carfull. There are a lot of clips and tabs to get the entire grill apart.
When pulling the grill off the jeep slowly work the clips off. Don’t rush or you risk cracking the grill.
Once the grill was pulled out I made the mistake of placing it on some cardboard on the ground and scratched up the front of the grill on the vertical slots. Sooo annoying. I think they will buff out but did not get a chance to do that yet.
Before and after:
Hope this help. Any questions let me know!
VFL865
Austin
DMV
Jeep JL Unlimited Sahara
Did you paint the replacement bezels or did they come this color? I can’t tell if the unpainted bezels match the factory bumper, yes I’m colorblind lol.
Woodynj
Woodynj
Justin
NJ
2018 JL Sahara
I did not paint them. The way they come they match really good.
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Are those not the same as the Rubicon ones? They look more black.
Woodynj
Woodynj
Justin
NJ
2018 JL Sahara
jwmmr
2018 Jeep Wrangler jl
Did you sell your Silver pieces? I am looking for a set.
jeepster345
Hunter
Homestead, FL
2018 Jeep Wrangler JLUS
I've got the silver grill pieces if you're interested. Unfortunately, my silver bumper trim was damaged, so I had to toss it.
Woodynj
Woodynj
Justin
NJ
2018 JL Sahara
I have the grill pieces but also damaged one of the bumper pieces getting it off.
Kraty1
Batavia IL
2018 Jeep Wrangler Unlimited JL
Sales & Marketing
Thanks for this post, exactly what I needed to see. I’m going to plastidip my grill inserts and bezels. Appreciate the how to remove the bezels!
k_griffs
Kyran
Montréal, QC
2019 JLUS
Great info! Do you by any chance have the Mopar part numbers of the fog light inserts and grill/headlight inserts needed to make this swap?
ECHOPLEX
Ian
Ottawa, Canada
2019 JLUS
Trim Bezel - Mopar (6BU59TZZAA)
Trim Bezel - Mopar (6BU58TZZAA)
Trim Panel Assembly - Mopar (6CG99TZZAC)
Note there are two distinct part numbers for the fog fight bezels (left and right side).
Grill/headlight has three sections under the one part number.
marcdm
Marc
Bay Area, CA
2018 JLU Sahara... preceded by 2012 JKU Sahara, Multiple CJ's, TJ's even XJ, WJ & WK2... yup, Always loved my jeeps :)
Super helpful thread. Ive just ordered by the grill insert and the new bezels. So Ill be hoping to take this on next weekend~
marcdm
Marc
Bay Area, CA
Like I said, this thread was super helpful! I took out all 4 of the plastic shield plugs on the bumper to get to the Fog Bezel. It did make it easier as you have to bend it back if you only take out the 3. Thankfully, I had ordered new OEM bezels and grill inserts as I did crack both bezels prying them out.
That being said, the process was so much easier with the tip from this thread than from others. You definitely don't have to take out the full bumper cover to get to these. That would have been far more work!
After having swapped out the fog bezels. That already makes such a difference. What I never liked about the silver inserts is how it changes the focus of the front to the outside of the bumper edge vs the focus on the iconic Jeep O|||||||O 7 slot grill~
Taking the grill out is a little bit of a mind bend... It bends and makes you worry that it could crack. Especially since I did crack both bezels removing. I just took extra time and you can feel each clip disengaging.
I took a couple photos of the grill prior to getting started so that if I had any questions as to the various screws, tabs, clips etc I could reference as I put it back together. I was glad I did, because the very last clips at the base of where the grill mesh went in had me scratching my head. It's not complicated, It was just nice to have a reference.
All the videos I watched made pulling the insert out look a bit easier than mine. Both the light inserts took a bit of force and twisting to pull out. Again, I just took my time and each came out tab at a time until that f'ugly silver was out!!!
As I mentioned, it did take bit of force. A minor battle with one of the tabs and my thumb took a defeat from some stubborn Ohio made plastic! ;)
I was super happy upon getting it all back together and seeing the black accents vs the silver. For a while I had contemplated just getting a Mopar satin grill replacement vs changing out the inserts. But I love the granite paint color and am happy I went this route instead as the accents give it a really nice detail while still keeping the continuous paint match theme to my Jeep.
Getting the grill back in once you have it all back together was a synch. You simply line it all up and gently press in watching that to tabs up top slowly align as each tab click into place. The pin's go back in super easy also.
Man, do I love the look! I really simplifies the front end and gives the Jeep a really classic look while still feeling stock. Ideally, I do want to swap out the bumper to steel... but not yet an expense Im ready to pull the trigger on. This however, was a super inexpensive way to black out the front until Im ready to swap the bumper~
Anyhow - This thread helped me immeasurably. So hoping my additional context may help someone else~
Awickedbeast
Eddie
KY.
2021 Jeep Sahara Unlimited High Altitude
Factory Mechanic
Man, do I love the look! I really simplifies the front end and gives the Jeep a really classic look while still feeling stock. Ideally, I do want to swap out the bumper to steel... but not yet and expense Im ready to pull the trigger on. This however, was a super inexpensive way to black out the front until Im ready to swap the bumper~
Thank you for your post and pictures. I must do this to my Sahara ASAP, that silvers gotta go. Thank you and all the others that have posted helpful advice on how to do this. Posting a pic for attention. I’ll post another when I get the silver swapped out. Thanks again.
