SRQgunner
- Russ
- Oct 29, 2019
- Sarasota FL
- 2018 Jeep Wrangler JL Unlimted Sport S
- Vehicle Showcase
- 1
Run fuse 57 setup as is except bypass headlights altogether, just that 57 wire to both fender lights (white wire w/ brown stripe, this is the wire you cut and replace w/ new 57 wire). This will keep the DRL function lit when the ignition is on and you can still use your auto light function on the dial.
I have factory OEM LED headlights on my 2018 Sport S that were installed at the dealership. I was told by the technician he connected the HALOS (which work as DRLs also) directly to the BCM module and not the fuse box so I should have fuse 57 available as I do not have heated seats.
I have ordered the Oracle 7443-CK and want to run them (the white part) as DRLs too. So if I understand correctly I would just need to use the fuse 57 set up by cutting the white/brown and white orange wire on the respective turn signal and splicing in the fuse 57 setup wire that leads into the turn signal lamp correct? The wire that I cut which leads back into the cabin I would just tape up to protect it.
And this would not cause any problems? Thanks in advance for your reply.
