Tires cupping
RenegadeJeeper
Edmond OK
2018 Stingray JLU sport
All stock.
Outside of tires are cupping at just 1700miles.
Took to dealer and they say everything is in spec on alignment.
Any reason this would happen?
Besides tow.
Renegade
Zac
Signal Mountain, TN
‘20 JT
Post a picture. It sounds like feathering rather than cupping. Toe-in could be the cause...
Jondrew
Bob
Central Fl
2018 Rubicon
And if the dealer says that’s normal, take it to an alignment shop that knows what its doing
RTJ
Rob
Seattle, Wa
2018 Jeep Wrangler JL Sport Unlimited
All stock.
Besides tow.
What's your air pressure at?
WXman
Central Kentucky
2018 Wrangler Unlimited
Probably toe setting is off spec.
Sorbs
Brian & Sunny
Colorado Springs
21' Ram TRX, 20' Gladiator LE
Get it aligned at a shop. My tires were doing the same. The alignment specialist stated that when new vehicles are strapped down for dealer delivery it can easily put the vehicle out of spec. Now, ours steers straight, no vibration, and my tires are fine.
Also, does your dealer have an alignment rack or did they use a measuring tape? A lot of dealers would send it out to a shop so make sure they’re not blowing smoke and actually did something to check it. They’d include an alignment report that shows it in spec or not.
USNJeeper
VA
2018 JLUS, 95 YJ
Definetely take it to a shop and have it checked. If it comes back out of alignment take the sheet to the dealer and show them. haha. I personally use firestone as you can spend the coin and get lifetime alignments. It entitles you to adjustments and you pay for it up front last time I did it was 140 something I think but I could take it back multiple times if I hit a pot hole, or banged it around on the trails.
Renegade
Zac
Signal Mountain, TN
‘20 JT
So here we are a year later...
What have you done to it to alleviate the problem?
RenegadeJeeper
Edmond OK
Took to alignment twice and no issue they said
