- Banned
I've read that several on here are using weight distributing hitches. What brand? Any good or bad feedback on them? Any concern with using one on a class II hitch? Thanks.
It depends a lot on how much weight you want/need to transfer from the rear axle to the front axle and trailer axle(s) if you should use a WD hitch.I've read that several on here are using weight distributing hitches. What brand? Any good or bad feedback on them? Any concern with using one on a class II hitch? Thanks.
Thank you. Your opinion is appreciated. I don't entirely disagree with you. I find hitch and weight ratings to be kind of obscure. I'm not an engineer so I probably don't know what I'm talking about though. Can I ask about your wreck with a WD setup? Was there a towing capacity threshold you were exceeding, knowingly or unknowingly?My opinion- so take it for what it's worth- is that if you are using a WD hitch on a Wrangler, you are probably over loading the Wrangler. But I fully admit I had a bad experience (wreck) with a WD setup, and at the time I didn't understand how all of the numbers and ratings related to each other.
