- Oct 7, 2019
- Metairie, LA
- Website
- www.oraclelights.com
- 2019 Jeep Wrangler JL
- Occupation
- Automotive LED Manufacturing
ORACLE 7" HIGH POWERED LED HEADLIGHTS (PAIR) - BLACK BEZEL - NO HALO - USED
Part Number: 5769-504
Certifications: CAPA, DOT, SAE
Regular Price: $263.35
Sale Price: $99
Fits Models:
1945-1985 CJ
1996-2006 TJ
2007-2018 JK
2018-2020 JL (*Brackets needed sold separate)
*USED
*Minor scratches and road wear
*Includes H13/H4 adapters
*No brackets included
*No Warranty
The Ultimate LED replacement headlight option for any vehicle with 7â Sealed Beam lamps. The rugged design is perfect for your Jeep Wrangler, Off-Road Vehicle, Buggies, or Classic Car/ Truck. Installation is very easy with the included H4 and H13 âPlug and Playâ connectors.
Latest Product Improvement
⢠Improvements in brightness and reliability by adding a constant current LED driver to the main circuit board inside of the lamp to control the halos.
⢠NEW! No need for Anti-Flicker Wiring Adapters- The new SMART Integrated Can-Bus system automatically adjusts- preventing flicker issues.
⢠Increased Reliability- By conditioning the power going into the LEDs this prevents degradation which can shorten the overall lifespan of the product.
⢠Wider Input Voltage Range- The new SMD Halos can operate on a very wide voltage range from 12V-24V so that voltage spike can not damage the LEDs.
⢠Brighter LED Halos- by moving the heat load of the resistors off the PCB we are able to increase the number of LEDs on the circuit board without thermal issues.
⢠LED chips upgraded from a Cree LED to a Phillips Luxeon ZES chip.They deliver a very high efficacy 130LM/W ratio while having lower thermal output.
Product Features: (Per Light)
⢠Low Beam Wattage: 30W Normal/36W Max
⢠Low Beam Lumens: 2200 Lumens/3600 Raw Lumens
⢠High Beam Wattage: 40W Normal/48W Max
⢠High Beam Lumens: 3600 Lumens/4800 Raw Lumens
⢠Color Temperature: 6000K (Cool White Color)
⢠Input Voltage of Light: 12-24V DC
⢠Input Voltage of Halo (If Included): 12V DC
⢠Current Draw: 2.50 Amps @ 12V DC / 1.30 Amps @ 24V DC
⢠Premium Performance Phillips Luxeon ZES LEDs
⢠Die-Cast Housing with Corrosion Resistant Coating
⢠Heavy Duty Solid State Electronics
⢠Hard-coated Polycarbonate Lens
⢠Wide Beam Pattern with Sharp Cut-Off Line
⢠Easy Plug & Play Installation
⢠DOT and SAE Certified
Wiring for Halos:
⢠Red Wire is (+) the positive wire
⢠Yellow Wire is (-) the negative wire
Sale Price: $99
Fits Models:
1945-1985 CJ
1996-2006 TJ
2007-2018 JK
*USED
*No Warranty
Wiring for Halos:
