cbrenthus
The TazerJL does a lot more than read / reset codes - it can do things like change the tire size for the speedo, diabsle ESS, and many, many more...
However, there are basic code readers that are just OBDII scanners. These will read the code and let you reset it, that's it. They can be found starting around $30, and are a great tool if you are doing any of your own work in a garage. I believe that is what a few people have reset the code with. If no one confirms this, I can check later to make sure mine will do it. This is similar to the one I have (mine is quite old, 10 years give or take).
https://www.harborfreight.com/obd-i...MI45rW8I7t5wIVh5-zCh3l7AJeEAQYAiABEgLcRPD_BwE
