Rancho RS9000XL are now here for the JL!
Status
Not open for further replies.
Redneck_Jedi
Currently Roaming
2019 Jeep Wrangler Sport S 2 Dr.
@RanchoShocks
For a 2 Door Sport with a 1.5-2in lift, do you recommend RS999063 and RS999064 ?
Also, any upcoming rebates? ;)
Thanks!
RanchoShocks
RanchoShocks
CA
www.gorancho.com
2013 JKU
I would go with the part numbers you listed. Should be good for up to 2". Anymore I would suggest the longer PN's.
And no rebates that I have seen for the start of 2020.
@RanchoShocks
Thanks!
Redneck_Jedi
Currently Roaming
Thanks Matt, much appreciated. I wasn't sure if there was a different part number for a 2 door.
mgroeger
Hurricane, UT
go to www.northridge4x4.com and use the coupon code jlwranglerforums for 10% off. We have been running the RS5000 version which are the non adjustable version and just a heads up they were a little firm and only got more firm as time went on. Moving on to Falcon 3.1 now.
Redneck_Jedi
Currently Roaming
@RanchoShocks
Hi,
Sorry, one more quick question. Do you know if RS1952 (black, 9.5" boot) , is the correct size for the RS999063 and RS999064 shocks? thanks.
Redneck_Jedi
Currently Roaming
The rebates should be offered any day now. I think last year they started on March 1st.
OBJLU
Henry
Los Angeles
2018 JLU Rubicon
I like these shocks, I run them now but how much travel do these really have? I see different numbers, more travel when “drs engaged” what’s the real number?
RNLROCK
Rich
New Jersey
Wrangler 4XE Sahara
Stock shocks right now?
I just bought a Sahara 4XE and was looking into changing the shocks without lifting it since the 4XE seems to sit 1" higher than the other Saharas.
Can I use the RS9000 series on the 4XE?
Thanks!
Rich
RanchoShocks
RanchoShocks
CA
www.gorancho.com
2013 JKU
Where are you located by chance?
I just might need your 4XE LOL
Thanks!
Rich
Status
