Somehow I managed to hit mine on really simple trail, no damage, but better safe than sorry....But I may never get around to making them work because when I looked after my last trip, the front control arm axle side bracket never hit the rocks so I don't think they are entirely necessary.
They do fit with our FAD skid.I have them but haven't got around to installing them yet because they don't fit with the Metalcloak FAD skid.
They shouldn't be loosening - sounds more like bushings that are worn out. Give your drag link and tie rod end bushings a look, and definitely check out your control arm joints..Installed skids some time ago and actually used them on couple of trails. And now I have a problem with front ones. It looks like I need to tighten bolts for fronts every other drive or they start to creak and moan each time I turn the steering wheel. I like the protection, but its getting annoying to the point I want to take them off.
I know they should not. But the creaking stops for a short time and the fact that I can actually tighten the bolt for a 100th time tells me that its loosening somehow. I'll take them off this weekend and inspect the bolts. If they dont look stretched, Ill use locktight or something. I'll inspect all the bushings again.They shouldn't be loosening - sounds more like bushings that are worn out. Give your drag link and tie rod end bushings a look, and definitely check out your control arm joints..
Blue Loctite?Installed skids some time ago and actually used them on couple of trails. And now I have a problem with front ones. It looks like I need to tighten bolts for fronts every other drive or they start to creak and moan each time I turn the steering wheel. I like the protection, but its getting annoying to the point I want to take them off.
