- Feb 27, 2017
- Silverdale, WA
- Website
- www.northridge4x4.com
- 2016 Sahara JKU, 2013 Rubicon JKU
- Occupation
- Seller of badassery
Northridge4x4 has the new TeraFlex Nomad Wheels in stock!
They come in a 17x8.5" size with a 4.75" backspace and are available in a Titanium Gray or a Metallic Black easy to clean finish.
Looking a little closer and you'll notice the dual red knobs. One is for airing up and the other is for airing down.
The air-up knob covers the Schrader valve to keep it clean and protected. Just unscrew it to access the valve stem.
The air-down knob is a TeraFlex proprietary Air Deflator that allows you to quickly air down to your preset air pressure. That's right, you set it to any psi you want, down to 10 psi minimum.
4.75" Backspace.
8.50" Width and look closely you'll see dual safety beads and serrations to help keep the tires on the bead even at lower pressures!
How strong are they? Teraflex has these made from heat-treated A356-T6 aluminum and rate them for up to a 40" tire!
So you are asking yourself where do you get these cool wheels???
For the Deluxe model with the Air-Down feature:
TERAFLEX NOMAD WHEEL - DELUXE 17X8.5 5X5IN - TITANIUM GRAY
TERAFLEX NOMAD WHEEL - DELUXE 17X8.5 5X5IN - METALLIC BLACK
Don't want the air down feature? Go for the Base model wheels (You can always add it later):
TERAFLEX NOMAD WHEEL - BASE 17X8.5 5X5IN - TITANIUM GRAY
TERAFLEX NOMAD WHEEL - BASE 17X8.5 5X5IN - METALLIC BLACK
4.75" Backspace.
