QTDDTOT: Questions that don't deserve their own thread
Chocolate Thunder
Jeremy
Here is where it is in relation to the rest of the windshield. From looking at the front, I’m assuming it’s a defroster for the sensor area for the ACC.
I never noticed it, but I have it too. I have the ACC pkg.
Jennalee
Jennalee
Los Angeles, CA
2020 White 2 door Willys V6 Automatic
So my manual says if something is plugged into the USB it will keep charging for an hour after you shut the car off. Won’t that drain the battery?
KIVO
Kid
Belgium
2020 Punk'n JLR 2.0
Practical engineer
Nah, the USB output is too limited to drain a battery in one hour, in particular not a new battery. No worries here ;)
Gee-pah
Andy
SanFrancisco
JL Wrangler
Front defrosters/defoggers work in part by blowing dehumidified air on the windshield right? I guess maybe hot air too as hot air can hold more moisture than cold and might help defog the windshield.
And that dehumidified air comes from aspects of the air conditioning system(???).
That said, how does front windshield defrosting work on base Sport JLs with no air conditioning?
Just curious, thanks.
Jennalee
Jennalee
Los Angeles, CA
I’m curious as well.
Jebiruph
Jerry
Iowa
2018 JLU, 2019 KL, 2020 JT
Cars have been doing this for many, many years. Air conditioners condense moisture out of the air, that's where the puddle of water comes from when you run the air conditioning in the summer. If a vehicle doesn't have air conditioning, then it's not dehumidifieing the air.
Gee-pah
Andy
SanFrancisco
JL Wrangler
My bad. I should have googled this. https://www.taylorautoglass.com/how-windshield-defogger-works/
Hot air, at least for the front glass, warms the windshield somewhat, allowing the air near it to hold more moisture and not have that moisture-causing-fog collect on the relatively colder windshield.
I see now that it's more about warmer temperatures blown on the windshield solving this problem that dehumidification. Although my vehicles, which have A/C, seem to also utilize this system's defogging through dehumidication capabilities.
The above reply, although appreciated, didn't address my curiosity on what part of the vehicle's defogging system causes the front windows to become defogged.
spurly
Zach
Nebraska
2019 Bright White JLUR
Does anyone know if the factory sway bar links on a Sport are the same length as the ones on a Rubicon?
jlroman2
Jorge
Chicago, IL
2018 Jeep Wrangler JLU Sahara (Granite)
BCBA
Does anyone know where I can find the torque specification for lug nuts on an aftermarket tire? I have Black Rhino Barstows but had no luck finding this information on their website.
mgroeger
Hurricane, UT
Lug nut torque is independent of rim. It will be the same as factory.
jlroman2
Jorge
Chicago, IL
BCBA
Really? Even if it's on bigger tires? Currently running 35s.
mgroeger
Hurricane, UT
I just mounted 37s on beadlocks and had Costco balance them for me and they torqued the lugs down to factory specs. It's the bolt that has torque applied to it not the rim.
jlroman2
Jorge
Chicago, IL
BCBA
Thank you. Sam's club was refusing to remove the nail on my tire because they claimed bolt torque had changed. Will have to try another. Or do you happen to know if Costco does this work too with the membership?
