twa8000
Tom
Wisconsin
2019 JLU, 2009 JKU, 2014 WK2
Just picked up this 2019 that was under water (Freshwater) for nearly 90 minutes. I’m in the process of totally cleaning and restoring all the electronics at the moment. I will continue to update this thread along the way if there is interest in the project.
Mechanical Items water check.
HAD WATER IN IT
  • Engine
  • Front Diff
  • Transmission
NO WATER
  • Rear Diff
  • Transfer Case
Electronic Modules
  • TIPM (Fuse Box) - Bad / Replaced
  • BCM (Body Control Module) - Bad / Replaced
  • PCM (Powertrain Control Module) - Good
  • ABS (Anti-Lock Brake Module) - Good
  • IPC (Instrument Panel Cluster) - Bad / Replaced
  • TPM (Tire Pressure Module) - Good
  • TCM (Transmission Control Module) - Good
  • ORC (Airbag Module) - Good
  • RFH (Radio Frequency Hub) - Bad / Replaced
  • EPS (Electronics Power Steering) - Good
  • PTS (Parktronic System) - Bad / Replaced
  • OCM (Passenger Seat Module) - Good
  • HCP (Hybrid Control Pack) - Good
  • SCCM (Steering Column Control Module) - Bad / Replaced
  • ESM (Electronics Shift Module) - Bad / Replaced
  • DTCM (Drive Train Control Module) - Bad / Replaced
  • BPCM (Battery Pack Control Module) - Good
  • DPDM (Driver Presence Detection Module) - Good
  • SGW (Security Gateway Module) - Good
  • DASM (Driver Assistance System Module) - Good
  • ASBS (Automatic Sway Bar System) - Good
  • HVAC (Heater Vent Air Conditioning) - Bad / Replaced
  • CMCM (Radio) - Bad / Replaced
  • HSCM (Heated Seat Control Module) - Bad / Replaced
  • RBSS (Right Blind Spot Module) - Good
  • LBSS (Left Blind Spot Module) - Good
  • ICS (Integrated Center Stack) - Bad / Repaired
  • AMP (Radio Amp) - Bad / Replaced
  • PTCM (Power Top Control Module) - Bad / Replaced
Jeep Wrangler JL 2019 Rubicon JLU Flood Restoration Project 1
Jeep Wrangler JL 2019 Rubicon JLU Flood Restoration Project 2
Jeep Wrangler JL 2019 Rubicon JLU Flood Restoration Project 3
Jeep Wrangler JL 2019 Rubicon JLU Flood Restoration Project 4
Jeep Wrangler JL 2019 Rubicon JLU Flood Restoration Project 5
Jeep Wrangler JL 2019 Rubicon JLU Flood Restoration Project 6
Jeep Wrangler JL 2019 Rubicon JLU Flood Restoration Project 7
twa8000
twa8000
Tom
Wisconsin
Wow interesting. Did it roll off the ramp when putting boat in or something?
Previous owner stated the ramp was very slimy that day. Jeep kept slipping backwards when trying to pull his boat out.
twa8000
twa8000
Tom
Wisconsin
HAD WATER IN IT
  • Engine
  • Front Diff
  • Transmission
NO WATER
  • Rear Diff
  • Transfer Case
Jeep Wrangler JL 2019 Rubicon JLU Flood Restoration Project IMG_0009
Jeep Wrangler JL 2019 Rubicon JLU Flood Restoration Project IMG_0021
Jeep Wrangler JL 2019 Rubicon JLU Flood Restoration Project IMG_0024
DaltonGang
Houston, Tx
2018 Wrangler JLU Sport S, Rubicon Suspension, Tires, and Rims. Firecracker Red
@twa8000 , is this going to be for personal use, or are you going to get it running, and sell it?
I foresee major major electrical Gremlins, down the road.
twa8000
twa8000
Tom
Wisconsin
Keeping it for myself to drive. Im pretty confident in my cleaning. I will be posting pics soon, But I have dismantled every computer/module and cleaning every junction/plug-in in the harnesses.
DaltonGang
Houston, Tx
I hope it all works out for you. I really do. You have your work cut out for you.
DaltonGang
Houston, Tx
