Also see the other 2022 EJS Jeep Concepts:
Jeep Wrangler Magneto 2.0 Concept
Jeep Rubicon 20th Anniversary Concept
Jeep ’41 Concept
Jeep D-Coder Concept by JPP
Jeep Bob Concept
Jeep Birdcage Concept by JPP
Designed as a wide-open-air extreme 4x4 machine, the Jeep Wrangler 4xe Birdcage concept showcases a variety of custom accessory innovations from JPP and Mopar, while also proving its industry-best capability, as well as its class-exclusive, off-road 4xe plug-in hybrid powertrain.
Riding on an industry-first JPP 2-inch lift kit with FOX shocks, specifically engineered and tuned for the plug-in hybrid electric Wrangler 4xe, the vibrant Eagle Brown off-roader features Granite Crystal metallic and various signature Jeep 4xe Surf Blue accents.
Improving the front approach angle on the Wrangler 4xe Birdcage concept is a custom rock-slider skid plate that connects two rounded 2-inch steel support bars, integral to the custom seven-slot grille. The slider plate protects the recessed Warn winch, optimally placed for improved rock-crawling performance. For a unique appearance, two low-mount, Surf Blue closed-tow hoops are securely attached behind the skid plate to the side of the frame for improved tow performance.
JPP five-spoke beadlock wheels measure 17 by 8.5 inches and are mounted with BFGoodrich KM3 37-inch tires. New custom flat-fender flares and wheel liners, designed specifically for larger wheel/tire combinations provide additional clearance.
The flat fender flares have integral removable daytime running light (DRL) covers for the off-road enthusiast who may require extra tire clearance for extreme off-road situations. This concept is the first 50-state legal fender flare with OEM DRL and meets 50-state tire coverage requirements.
For additional off-road protection with 37-inch tires, the Jeep design team created taillight spacers to meet federal lighting requirements. The resulting location of the light assembly enables the concept aluminum taillamp guards to better defend from trail mishaps.
Illuminating the ground below the Jeep Wrangler 4xe Birdcage concept are underbody rock lights at all four corners while custom rock rails on each side feature additional slider tubes mounted for enhanced body protection.
For the serious off-roader who craves true open-air wheeling, the windshield and windshield wipers are removed. The design team tastefully closed off the instrument panel and created custom cowl and windshield-wiper filler panel covers, creating a smooth factory appearance while protecting against dirt and debris. Three concept header-mounted 14-inch JPP TYRI off-road LED lights provide sleek, modern lighting.
On the interior, Tobacco Leaf and Cocoa Brown leather seats feature distinctive seat inserts and Surf Blue accent stitching, which carries through on the instrument panel, steering wheel, shifter boot and emergency-brake handle.
Front-seat occupants will find a custom JPP instrument-panel accessory rail that holds various mobile devices securely in place. Mopar stainless-steel pedal covers use black rubber pads to provide the driver with plenty of traction to the accelerator and brake pedals. Armorlite vinyl floor throughout the cabin provides a durable and easy-to-maintain surface with drain plugs for rinsing.
The Mopar design team created the Add-A-Trunk concept decklid panel that provides security for accessories when the roof is removed. Designed for any Jeep Wrangler model with the capacity to store a full-size cooler with ease, the Add-A-Trunk feature uses gas-assisted shocks to lift the decklid panel out of the way for easy access when the swing gate is open. Eight tie-down loops and five grocery-bag hooks provide extra functionality.
For additional storage, a 600-pound capacity Rhino-Rack cargo basket is securely mounted to the top of the roll cage.
Inside the tailgate panel, a JPP swing-gate flip-down table provides a perfect working or eating space and sits next to an integral on-board air compressor.
VIDEO:
PHOTOS:
VIDEO:
PHOTOS:
