2018 Wrangler Drops Camo, Shows Backup Camera, Roofline, Grab Handles, Signs of Foldable Windshield
  1. Administrator
    Staff Member
    Jan 14, 2015
    151
    70
    Garage Profiles:
    #1 Administrator, Feb 24, 2017
    Update - March 1, 2017
    We can now confirm that the JL Wrangler will retain its folding windshield!
    A supplier source has sent us this cropped image of an unpublished photo (top image) which shows a hinge at the bottom of the JL Wrangler's windshield. The image is small, but the hinge is clearly visible and supports what some sharp-eyed viewers spotted in the recent spy photos (bottom image).
    [​IMG]
    Update - Feb. 27, 2017
    The 2018 Jeep Wrangler Unlimited prototype has been spotted again providing the clearest looks yet at the roofline, windows, grab handles and ever-so-slightly visible top.
    These new photos provide a clear look at signs of a prominent hood bulge, larger and longer air dam below the front bumper that extends much lower to the ground, and the large A-pillar mounted grab handles on the driver and passenger side.
    Our sources have indicated that the JL will not only retain a foldable windshield, but Jeep has actually redesigned Wrangler to make it easier to fold up and down. The large grab handles are positioned as such to do double duty-- used as traditional grab bars for ingress and egress and when things get rough on the trail, as well as serving as a handle for lowering and raising the windshield from the interior. To make it even more convenient, the rearview mirror mount has been moved to the ceiling (as opposed to being mounted on the current model), as clearly shown in the photos.
    The fenders on the JL Wrangler appear to arch higher on the vehicle and have been reshaped for a more rounded look. In fact, many of the JLU's edges have been rounded for better aerodynamics, from the fenders to the windows, roofline and overall silhouette.
    There are also hints of the new black roof panels and though not much else can be discerned from the thin sheet of roof we see, we can tell that the ribs are similar to the current Wrangler's Freedom hardtop. Along with the folding windshield, this points to a highly open-air design.
    Here's what's clearly seen in these new images:
    • prominent hood bulge
    • larger and longer air dam/skid plate that extends much lower to the ground
    • large A-pillar grab handles on the driver and passenger side
    • rearview mirror mounted to the roof instead of the windshield
    • reshaped, more rounded fenders that appear to arch higher on the vehicle
    • rounded windows
    • hints of black roof panels
    Update - Feb. 26, 2017
    Our photos also reveal a new interior feature -- grab handles mounted on the A-pillar.
    They appear to be large and robust. It remains to be seen whether there will also be handles mounted in back for rear passengers.
    [​IMG]
    Update - Feb. 25, 2017
    Here's an image we can now share showing what’s under the camouflage of the production vehicle, with a comparison to the JKU roof line (below it). This is not photoshopped.
    [​IMG]
    You can see how the JKU's Freedom Hardtop fits over the rear doors and trunk cargo area while the JLU roof line shows clear separation between the entire roof and each of the windows, as well as the missing cut line where the removable rear top section would be. This suggests possibly a fixed C-pillar and fixed rear window, and may indicate a solid roof structure extending the length of the vehicle that also provides support for the 3-piece hardtop we expect to see on the JLU.
    Original post - Feb. 24, 2017
    Our spies have just caught the 2018 Jeep Wrangler Unlimited (JLU) out testing with a lot less of its disguise, showing for the first time an almost naked view of its side body panels, windows, door cut lines and roof line.
    While the overall design of the four-door JL Wrangler does not appear to stray far from the outgoing model, a few key differences can be seen from this prototype that still remains largely concealed.
    First, as expected the windshield and A-pillar have a noticeable rake, angling downward by a few degrees compared to the JK Wrangler. The JL’s new running board is also visible and shows a wider and tougher looking part with a step surface that runs the entire length of the front and rear fenders (unlike the JKU which has unusable contours near the fenders and between the front/rear doors). The running boards appear to be made from the same thick blow-molded textured plastic as that of the current model which should match the fenders on trims not equipped with body colored fenders.
    Both the door handles and hinges are covered up but suggest that the exterior door hinges will remain (and be as easily removable as the current model). The doors work their way up to the bottom edge of the roof line which appears to be largely unchanged and hints at a removable hard top on this prototype. The JL's drip rails also extend the entire length of the roof to the tailgate as opposed to the current JKU's rails that terminate after the rear doors.
    The tires spotted on this prototype are 18" Bridgestone Dueler A/T, the same tires as equipped on the current JK Wrangler Sahara. Previous JL/JLU prototypes have worn 17" BF Goodrich All-Terrain tires.
    The 18" wheels, Bridgestone Dueler tires, and running boards point to this as a Sahara edition JLU.
    The rear is still heavily covered in thick camouflage but peeking out from underneath is at least one new feature, a backup camera, that will be a first for the Jeep Wrangler.
    Compare to previous spied prototypes:
    http://www.jlwranglerforums.com/for...Strip-and-Headlights-Brightly-Lit-and-Exposed
    http://www.jlwranglerforums.com/for...uction-Grille-Exposed-Testing-in-Death-Valley
    New photos from Feb. 27
    New-2018-Jeep-Wrangler.LD01.KGP.ed.jpg New-2018-Jeep-Wrangler.LD02.KGP.ed.jpg New-2018-Jeep-Wrangler.LD03.KGP.ed.jpg New-2018-Jeep-Wrangler.LD04.KGP.ed.jpg New-2018-Jeep-Wrangler.LD05.KGP.ed.jpg New-2018-Jeep-Wrangler.LD06.KGP.ed.jpg New-2018-Jeep-Wrangler.LD07.KGP.ed.jpg New-2018-Jeep-Wrangler.LD08.KGP.ed.jpg New-2018-Jeep-Wrangler.LD09.KGP.ed.jpg New-2018-Jeep-Wrangler.LD10.KGP.ed.jpg New-2018-Jeep-Wrangler.LD11.KGP.ed.jpg New-2018-Jeep-Wrangler.LD12.KGP.ed.jpg
    New-2018-Jeep-Wrangler-Screen Shot 2017-02-27 at 10.55.55 AM.jpg New-2018-Jeep-Wrangler-Screen Shot 2017-02-27 at 10.56.04 AM.jpg New-2018-Jeep-Wrangler-Screen Shot 2017-02-27 at 10.56.13 AM.jpg
    Original photos from Feb. 24
    New-2018-Jeep-Wrangler_Less_001.jpg New-2018-Jeep-Wrangler_Less_002.jpg New-2018-Jeep-Wrangler_Less_003.jpg New-2018-Jeep-Wrangler_Less_004.jpg New-2018-Jeep-Wrangler_Less_007.jpg New-2018-Jeep-Wrangler_Less_008.jpg New-2018-Jeep-Wrangler_Less_009.jpg New-2018-Jeep-Wrangler_Less_010.jpg 2016-jeep-wrangler-sahara-side-view-in-motion.jpg
    COMPARISON TO JK WRANGLER:
    [​IMG]
  2. Dackel
    Dackel Well-Known Member
    Sep 27, 2016
    50
    San Clemente
    Car(s):
    2014 JKU, Ram 1500
    Finally! Why still the heavy camo covering the entire rear end. Surprise in store for pillar design, rear window shape, or rear gate?
  3. CorpCow
    CorpCow Well-Known Member
    May 18, 2016
    71
    Austin
    Car(s):
    Ram 1500 Quad Cab
    I like the running boards hope they come standard.
    Can't make out what tires those are tho. Doesn't look like the BF Goodrich ones on the earlier prototype.
    [​IMG]
    [​IMG]
    Vegas_Sirk likes this.
  4. Otto
    Otto Well-Known Member
    May 13, 2016
    53
    WA
    Car(s):
    Wrangler Sport (JK)
    Raised vent on the hood? Or maybe air is getting under the camoflage and raising it up.
  5. Vegas_Sirk
    Vegas_Sirk Well-Known Member
    May 20, 2016
    164
    39
    Boise, ID
    Car(s):
    2013 JKU
    Garage Profiles:
    Just going to post the same comment .... not BFGs on this :(
    Maybe the BFGs will be on Rubicon models and this is a Sahara?
  6. JJ75
    JJ75 Active Member
    May 11, 2016
    27
    Corona, CA
    Car(s):
    2012 JKU
    Could be hiding how the new multi piece roof will look and work.
  7. Vegas_Sirk
    May 20, 2016
    164
    39
    Boise, ID
    Car(s):
    2013 JKU
    Garage Profiles:
    Roof looks a lot the same which I'm surprised about, but I think I see a bulge around the rear window which mean that the camo might be covering up the removable panels.
    JJ75 likes this.
  8. JLWranglerJT
    JLWranglerJT Well-Known Member
    Feb 12, 2017
    145
    27
    Winston Salem, NC
    Car(s):
    1992 Ford Ranger XLT
    #8 JLWranglerJT, Feb 24, 2017
    FYI: The tires in the new spy shots are the Bridgestone Dueler A/T revo
    Running boards are too long and bowing in the middle.. Their trying to extended the old TJ running boards and in doing so, these looks terrible.. fail.. These would have to go..
    Oh forgot to mention.. if you're not aware of the zoom option within your browser to look at these and other image closer.. simply press hold the Ctrl key and use the mouse roller to roll forward or back to zoom in or out..
  9. ModdedJK
    ModdedJK Well-Known Member
    May 5, 2016
    93
    Spokane, WA
    Car(s):
    Modded JK
    The running boards look much more useable. More surface area and they're deeper too.
    I'm calling it now - full swing out door and window (together). Camo seems to preview it.
  10. Warrior Class
    Warrior Class Member
    Nov 29, 2016
    VA
    Car(s):
    2014 Rubicon, Yamaha Raptor 660
    Nice to see new pics it's been a while. Interesting placement for the backup camera - looks like it sticks out from the center hub of the wheel, so center caps can't be installed onto the spare when it's mounted on the rear. Will have to be more careful when mounting the spare compared to the JK.
  11. JCC
    JCC Member
    Feb 21, 2017
    Denver, CO
    Car(s):
    None
    I think you're right based on what looks like the zippers on the back camo. It'll be interesting to see how that is engineered with a removable hard top. I'd also assume that the flip up window would no longer be an option, which I think is a shame. I used that function a lot (for lumbar yard runs and such).
    Davos77 likes this.
  12. Davos77
    Davos77 Active Member
    Dec 23, 2016
    38
    Indiana
    Car(s):
    2003 Wrangler Rubicon
    Garage Profiles:
    Good call on the zipper, didn't notice at first glance. I'd be ok with a full swing out door and think it'd even be kinda cool but it'd be a mistake to make the rear window fixed. If the new generation gets some kind of fixed roof structure as rumored then it'll need all the removable and open-able windows and panels possible to deliver a semblance of open air driving. That, and it'd be a downgrade from now to lose the utility from a rear window that actually opens.
  13. AVENTUS
    AVENTUS Well-Known Member
    Sep 7, 2016
    114
    Chicago, IL, USA
    Car(s):
    BMW 750li sport
    I get the strong impression of far more rounded edges on this JLU. Especially roof lines, bumpers, and fenders, which is a good thing.
    I also like the fog lights being slightly wider than the main headlamps, which is quite apparent.
    I'm one of the dudes who doesn't like the rear door on JKU. A fold down tailgate would be much more welcome.
  14. DropTopGal
    DropTopGal Active Member
    Feb 7, 2017
    27
    South Florida
    Car(s):
    TBA: 2018 JL Wrangler, 2017 GS Corvette
    Garage Profiles:
    Good post, thanks! I think we all are in for a real treat, better than expected.
  15. MDWG
    MDWG Active Member
    Jan 30, 2017
    Brandon, FL
    Car(s):
    YJ, Dodge Journey, Toyota Corolla
    Awesome, nice to see skme more photos finally. The JLU looks extremely long compared to the JKU or is that just my imagination.
  16. Frank
    Frank Member
    Jan 16, 2017
    Italia
    Car(s):
    Wrangler jk
    Garage Profiles:
    Hello everyone I hope to soon see the three-door version and the new interior.
    Gavin and JLWranglerJT like this.
  17. AVENTUS
    Sep 7, 2016
    114
    Chicago, IL, USA
    Car(s):
    BMW 750li sport
    [​IMG]
    The rear end looks like it might be very round/bubbly/sexy, I hope it's not just the clothes making it look that way!
  18. JoKer
    JoKer Well-Known Member
    Jan 12, 2016
    127
    Midwest
    Car(s):
    '13 Wrangler Sport
    Slightly more rounded window edges on the JLU.
    [​IMG]
    [​IMG]
  19. JoKer
    Jan 12, 2016
    127
    Midwest
    Car(s):
    '13 Wrangler Sport
    I'd prefer fold down tailgate too but hard to do when the spare tire is mounted on the tailgate. Spare would have to be moved up or rear bumper lowered to allow clearance. Plus didn't we already see a JLU prototype with a swinging tailgate?
  20. The Doc
    The Doc Member
    Oct 25, 2016
    24
    Illinois
    Car(s):
    2011 Wrangler Unlimited, Future JT Pickup (hopefully)
    Of all the things on the side to cover up interesting that they hide the hinges and door handles. What could it possibly be hiding? Keyless entry? Better not be any chrome hinges or anything like that.
Share This Page
