2017-18 Wrangler (JK, JL, JT) Toledo Assembly Plant Schedule
  1. Administrator
    Staff Member
    Jan 14, 2015
    160
    89
    Garage Profiles:
    #1 Administrator, Jan 4, 2017
    Here is the latest 2017-2018 Wrangler (JK, JL, JT) schedule for the Wrangler Assembly Plants.
    Current: TSP (Toledo Supplier Park - Toledo South)
    • Building 2017 JK Wranglers until 9/30/2017
    • Will build 2018 JK Wranglers starting 10/02/2017 until 3/30/2018
    • Will shut down starting 3/31/2018 for an estimated 6 months to retool for the 2019 JT Pickup which begins production in October 2018
    Future: TNAP (Toledo North Assembly Plant)
    • Currently building 2017 Jeep Cherokee KL until 4/07/2017
    • Plant will shut down from 4/08/2017 until November 2017 to prepare for Wrangler JL production
    • All-New Wrangler JL will launch 11/13/2017
    Note: Information is subject to change
    * Updated 02/15/17 with latest info.
    Bill P, jb1990, ModdedJK and 2 others like this.
  2. Dackel
    Dackel Well-Known Member
    Sep 27, 2016
    66
    San Clemente
    Vehicle(s):
    2014 JKU, Ram 1500
    Thanks for the info. I read some speculation that the plant might not need more than a few weeks for retooling because they were building a facility outside the current plant for building aluminum body parts. Also that the current and new bodies would have the same BOF attachment points, allowing for a short changeover period from steel to aluminum. Good to have more details!
  3. Taimaishu
    Taimaishu Member
    Nov 10, 2016
    NJ
    Vehicle(s):
    TJ
    But what does BOF attachment points have to do with changing over from steel to aluminum though? I thought none of the frame was going to be aluminum and only non structural parts would be switching to aluminum? The leaked alcoa memo mentioned front and rear door inners, hood outer and inner.
  4. Dackel
    Sep 27, 2016
    66
    San Clemente
    Vehicle(s):
    2014 JKU, Ram 1500
    It's based on the fact that steel dust can contaminate any aluminum parts causing it to corrode and any paint applied on top of the contaminated parts to erode the paint. This means they have to build a clean room attached to the paint shop to thoroughly clean the aluminum parts prior to painting.
    If they can use the new facility to do so the existing line can avoid a prolonged plant shutdown if the tooling for the JK and JL can be married. Theory being it's possible if they have the same BOF attachment points. That's how I understood it at least but this may have been more relevant if the JL was going to be an all aluminum body. Now that we know it isn't it may be a moot point and from the info posted in the OP it seems the second line will be shutting down for a very long time before JL production starts.
    The Mad Duck and Cam like this.
  5. ModdedJK
    ModdedJK Well-Known Member
    May 5, 2016
    101
    Spokane, WA
    Vehicle(s):
    Modded JK
    Wow that's a long shut down for Toledo North. Only 1 to 2 months for the current line? i'm no expert on this but for all new model that sounds like a quick retooling time. Another sign it won't be a drastic change I would think.
  6. F1Mark
    F1Mark Member
    Nov 14, 2016
    middle of nowhere
    Vehicle(s):
    YJ
    Any word on where the JT will be built? Will additional retooling have to be done when it launches or will the shut down for JL tooling take care of that?
  7. Milous
    Milous Active Member
    Dec 17, 2016
    41
    51
    Nott Shure, Wair
    Vehicle(s):
    Yes
    JT = current plant (Toledo Supplier Park) after retooling.
  8. OP
    Administrator
    Staff Member
    Jan 14, 2015
    160
    89
    Garage Profiles:
    Update/Revision:
    • Will shut down starting 3/31/2018 for an estimated 3-4 months or longer to retool for the 2019 JT Pickup
    Jeep XXL likes this.
  9. Jeep XXL
    Jeep XXL Active Member
    May 12, 2016
    42
    Vegas
    Vehicle(s):
    Jeep Wrangler
    The pickup is really starting production in mid 2018?? I want to believe that sooo bad.
  10. Milous
    Dec 17, 2016
    41
    51
    Nott Shure, Wair
    Vehicle(s):
    Yes
    Most likely a little later, still trying to narrow it down.
    Bill P likes this.
  11. Cam
    Cam Active Member
    Nov 3, 2016
    Indiana
    Vehicle(s):
    In between Wranglers right now
    So only JT Wrangler pickup will be built on Toledo South line after it stops making the JK? If thats the case they must be different enough in production to not use the extra capacity to also build the JL or JLU on the same line as the JT.
  12. jb1990
    jb1990 Active Member
    May 26, 2016
    South Carolina
    Vehicle(s):
    97 TJ Wrangler
    It says "starting 3/31/2018 for an estimated 3-4 months or longer" so it could be August or later based on that. With a totally new vehicle I would always err on later. It might end up only a month or so earlier than what most people expected.
  13. Jeep XXL
    May 12, 2016
    42
    Vegas
    Vehicle(s):
    Jeep Wrangler
    Keep us posted please! I can hold off until summer but if closer to winter I may give in and look at a RAM 1500. I'm hoping the JT is a serious pickup and not one of these JK conversions out there now.
  14. Bill P
    Bill P Active Member
    May 11, 2016
    34
    Sonoma County
    Vehicle(s):
    Wrangler Unlimited
    I hope it is true and if it is kudos to FCA for not being lazy or cutting corners with the JT. It's the best way to ensure big pickup sales to justify it's own line in Toledo.
  15. Vegas_Sirk
    Vegas_Sirk Well-Known Member
    May 20, 2016
    193
    50
    Boise, ID
    Vehicle(s):
    2013 JKU
    Garage Profiles:
    Its not going to be full size. No way FCA will canibalize their Ram sales .... the JT will be 100% a Tacoma / Canyon / Colorado / Ranger competitor of similar size. So if your not happy with the AEV Brute I doubt you'll be happy with it.
  16. Jeep XXL
    May 12, 2016
    42
    Vegas
    Vehicle(s):
    Jeep Wrangler
    I sort of expected that but willing to wait and see. If it's a stretched JL with at least 6' bed I would think long and hard about it. Good towing rating is key too. That's where it needs to separate itself from the Wrangler.
  17. Alx
    Alx Member
    Dec 6, 2016
    Somewhere Cold
    Vehicle(s):
    Self Built
    Yes.
    TSP will not build JL, only JT after retooling. TNAP will be converted to BOF for the JL and JLU only. The JT can't fit the current JK line so it will build the JK until JT is ready for launch. Hence, the overlap.
    The Mad Duck likes this.
  18. The Mad Duck
    The Mad Duck Member
    Feb 14, 2017
    2000 Van Horn Rd. Trenton, Michigan
    Vehicle(s):
    2011 Dodge Nitro R/T 4X4 (My Fake Jeep), 2010 Dodge Journey R/T, 1962 Imperial
    #18 The Mad Duck, Feb 17, 2017
    I Would Bet a Large Amount of Money at Very Big Odds that the Toledo North Plant Making the JT Would Also Have the Capability to Make the JL and or the JLU on the Same Line at the Same Time as Needed ! ! ! ! ! ! ! ! !
    A BOF Vehicle is Slightly Less Complicated that a Uni-Body One as Far as Body Panel assembly Goes .
    Can You Spell Spot Welding Fixture !
    To Not Have that Capacity Would be Really, Really Dumb!
    Besides It Would Not be that Hard to Do. These Models are Very Closely Related !
    You Could Meet the Changing Demands of the Market in a Very Short Period of Time.
    And You Never Know What Model Will be the Best Seller.
    Next this Model of Jeep Prints Money, Period.
    My Duck Hunting Buddy who is a Salesman at a CDJR Dealer has to Laugh when he Walks by a Jeep Jeep (Wrangler or Unlimited) and Says want to See the Program (a Sales Promotion Price) on the Jeep - He Points at the Sticker Price.
  19. DropTopGal
    DropTopGal Active Member
    Feb 7, 2017
    South Florida
    Vehicle(s):
    TBA: 2018 JL Wrangler, 2017 GS Corvette
    Garage Profiles:
    Other manufacturers make multiple models of the same year on the same assembly line, so why not Jeep.
Loading...
Similar Threads - 2017 Wrangler (JK Forum Date
KBB 2017 Best Resale Value Awards: Wrangler @ 4th spot Non-Wrangler Related Discussions Jan 26, 2017
Marchionne: 2018 Jeep Wrangler May Debut at 2017 LA Auto Show General JL / JLU Wrangler Discussions Jan 12, 2017
Jeep CEO- new Wrangler "probably" not debuting until second half of 2017 General JL / JLU Wrangler Discussions Dec 7, 2016
2017 Jeep Wrangler Gets LED Headlights Ahead of 2018 Redesign General JL / JLU Wrangler Discussions Sep 1, 2016
New Jeep Wrangler to Lose Weight, Confirmed 1st Half 2017, Jeep Pickup in Early 2018 General JL / JLU Wrangler Discussions Jun 24, 2016
Concepts revealed for Easter Jeep Safari 2017 General JL / JLU Wrangler Discussions Mar 28, 2017
Share This Page
